Nick,
Here's the server log. I can dial from one Softphone to the other. This only seems to happen when I dial the Uniden Phone. This is most likely a setting for the phone. I have also included the unidencom.txt file which has most of the configs.
Server logs:
00:23:39.671 AuthMgr:
nAuthSuccess: Extension "Server Account"<sip:
[email protected]>;tag=22778 has been registered successfully
00:23:35.015 Terminated c8 "Server Account"<sip:
[email protected]> <sip:
[email protected]> Call ended
00:23:18.921 Calling c9 "Server Account"<sip:
[email protected]> Send INVITE to Ext:199
00:23:18.921 Routed c9 "Server Account"<sip:
[email protected]> From: Ext:198; To: Ext:199
00:23:18.921 CallConf::findDestination: Found destination Ext:199 for caller Ext:198
00:23:18.906 Registrar::checkAor: Registrar resolved sip:
[email protected] as <sip:
[email protected]:5060>
[email protected]:1307>
00:23:18.890 Incoming c9 "Server Account"<sip:
[email protected]> Incoming call from 198
00:23:18.890 AuthMgr:
[email protected]>;tag=19332 has been registered successfully
Uniden Config:
# UIP200 Mass Configuration System Generic File
# Notes:
# 1. Lines start with '#' are comments
# 2. To leave a field value unchanged (as saved on local phone), leave value to blank.
# 3. To set a field's value to empty, use '-' as value.
# 4. To NOT overwrite user local settings of: programmable key, one/two touch keys, VMA
# number, VMWILampIndicator, set "OverwriteLocalSetting = NO". Default is "YES". This
# key will ALSO affect whether or not THESE settings in uniden<MAC>.txt be used.
# 5. Any duplicate parameters exist in both unidencom.txt and uniden<MAC>.txt, MAC settings
# will be used.
# MAXIMUM FILE SIZE IS 10KB
# Current Limitation: No spaces allowed for a setting's value
# Version: 4.59a
#Overwrite user local settings of programmable keys, one/two touch keys, vma settings
#If set to no, these current settings on the phone will not be overwritten.
OverwriteLocalSettings YES # must be placed on top of config file
# Sip Settings --If only ProxyServer needed, set OutboundProxy1/Port same as ProxyServer/Port
ProxyServer 192.168.254.245 # can be an IP address or FDQN
ProxyServerPort 5060 # 0 to use default port
OutboundProxy1 192.168.254.245 # can be an IP address or FQDN
OutboundProxy1Port 5060 # enter a port number or 0 for default (5060)
OutboundProxy2 - # can be an IP address or FQDN
OutboundProxy2Port 0 # enter a port number or 0 for default (5060)
EmergencyProxy -
EmergencyProxyPort 0
Registrar1 192.168.254.245 # can be an IP address or FQDN
Registrar1Port 5060 # enter a port number or 0 for default (5060)
Registrar2 - # can be an IP address or FQDN
Registrar2Port 0 # enter a port number or 0 for default (5060)
DnsServer_1 65.32.1.65 # may not be necessary if use DHCP
DnsServer_2 65.32.1.70 # may not be necessary if use DHCP
RegisterExpireSec 3600
RegisterRetrySec 90
Q_Param 50
RegisterExpireLimitPercent 10
FailoverRetrySec 8
SipPort 5060
SRVRecordName - #_sip._udp.unisip.com
# options are ON or OFF
SessionTimerSupport ON
SessionTimerRefresher ON
SessionTimerMin 60
TimerInterval0 300
TimerInterval1 150
# Audio Settings
G711MuTxPacketLength 20
G711MuJitterBufferLength 10
G711MuJitterBufferMax 200
G711ATxPacketLength 20
G711AJitterBufferLength 10
G711AJitterBufferMax 200
G729TxPacketLength 20
G729JitterBufferLength 10
G729JitterBufferMax 200
LongHoldAlertPeriod 360
# options are ON and OFF
DiffServMode OFF
DefaultDiffServParam 192
RTPDiffServParam 160
# options are TRUNKMODE, CASCADEMODE, DISABLE
VlanMode DISABLE
VlanID 1
PcVlanID 2
#TftpAddress 192.168.254.214 # save to phone and used next time if not offered from DHCP
TimeZone -5
# choices are YES and NO
EnableDST YES
EnableSNTP Yes
# SNTP Server IP address
SntpServerIP time.apple.com
# Time period (in seconds) before recontacting SNTP server
SntpRetrySec 1800
# preferred codec are listed from most preferred, separated by commas and NO space
PreferredCodec g711u,g711a,g729
# choices are English, Spanish, and French
Language English
#choices are Enable and Disable
CallWaiting Enable
EmergencyProxyPrefix **
#Admin password must be numeric. Max is 6 digits. Format: oldpassword/newpassword
#AdminPassword 2002/1204
#end_of_file
