unified messaging
Discussion in '3CX Phone System - General' started by radelman, Feb 29, 2008.
  1. radelman
    Feb 21, 2008
    60
    3cx does not seem to want to forward voicemails as email. Voicemails are received in an extension but not forwarded. The email address in the extension is filled in as is the smtp server name. The user name and password are the same as my outlook voicemail account. Emails send and receive ok in Outlook.
    Would anyone be kind enough to let me know if I should be able to see the sent emails in outlook and perhaps why they are not being sent from 3cx. Would you also know how long it should take for 3cx to prepare and send the email?
  2. radelman
    Feb 21, 2008
    60
    Hi Matt, this is what I have set up:
    Mail server smtp10.*******.ca (the same setting as in Outlook)
    Reply Address voicemail@*******.com (email account name)
    Username for accessing SMTP server voicemail@********.com (email account name)
    Password for accessing SMTP server ********** (email account password)
    Special Voice Menu Extension Number ***
    Notify User when Extension is Added
    Does this look correct to you?
  3. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    A lot of times you don't need to fill out the username and password for smtp connection. So when it's not working with those ID details please leave them out. Maybe it will work then
  4. radelman
    Feb 21, 2008
    60
    Thank you so much, I am very grateful for your help. Your suggestion solved the problem.
  5. Philco
    Philco Member
    Nov 10, 2007
    364
    Hi, glad to see these posts.
    I cant seem to get voicemail sent via email, but I have the server account set up as it should be and as per the example as radelman. The only diffrence is I use Mozilla Thunderbird as the mail client which shouldnt make any difference.
    Tried with and without a username and password for the smtp server too. The voicemail remains on the 3cx server.
    Regards
    Phil
