Uniform Dialing Plan Auto Routing
Discussion in 'Ideas' started by cel, Nov 17, 2016.
Uniform Dialing Plan Auto Routing 5 5 1votes
5/5, 1 vote
  1. cel
    cel
    Jul 15, 2015
    34
    17
    If you bridge several 3CX system it should be possible to use a uniform dial plan between the offices with an automated routing. If you have a system spread over several sites with a 4 digit dial plan, the system should check wherever a 4 digit dialled number would be in the network.
    As presence is shared between systems, the dial plan should be shred as well.
    Additional to the auto routing between 3CX sites, there should be as well a check if you try to configure a new extension which already exist on a remote system.
    3CXDude likes this.
