uninstall 3cx tunnel aplication
Discussion in '3CX Phone System - General' started by asfuture, May 9, 2008.
  1. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    if i try to uninstall the 3cx PBX i can not uninstall 3cx tunnel aplication. what to do???
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    sc.exe windows command-line utility can uninstall anything. Re Tunnel - probably you can not uninstal the one which has been installed by VoIP Client. If it's the case - VoIP client uninstaller will uninstall it.
  3. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    thanks a lot archie. i'll try. but i ask myself why in this way???
