Unique CallID for each Call
Discussion in 'Windows' started by Tertius, Jun 29, 2016.
  1. Tertius
    Feb 24, 2016
    43
    Hello everyone,
    I've been working with the Call Control API and have had some great success thus far.
    I've been using ActiveConnections to try retrieve the CallID for each call. The CallID provided changes at different stages of the call I.E when AC.Status is "Ringing" then the CallID might be 3409. When the AC.Status is "Connected" the CallID changes.
    Is there perhaps another way of retrieveing an ID that links to a connection in it's entirety, not each stage of a call?
    Thanks for any help in advance! :D
