Unknow Ext Error
Discussion in '3CX Phone System - General' started by StarTrek133, Apr 3, 2012.
  1. StarTrek133
    Mar 7, 2012
    11
    Hello Everyone,
    Ok here is a good one , i have this error that keeps popping up and it popped up so much last night that the system black listed the ip address .. the thing I dont understand is from the log it seems to be coming from ext 123 .. which when I goto the ext screen doesnt exsists never did .. when I set the system I did everything as 4 digital exts ..
    the only thing that does seems strange as of late is when I go into the phone tab I have a new phone listed that is not mine ... but when I log into the phone I dont see anything about ext 123 either ..
    any advice ?
    Thanks ..
    11:19:48.828|.\Call.cpp(48)|Log5||??:Currently active calls [none]<br>
    11:20:20.830|.\Call.cpp(48)|Log5||??:Currently active calls [none]<br>
    11:20:24.951|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-1438492259 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:24.958|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-4024192106 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:24.967|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-2014531641 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:24.974|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-1735347065 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.157|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-1877006049 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.170|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-3020852692 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.188|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-1456175213 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.193|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-2936850166 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.207|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-3210869080 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.236|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-2501492690 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.246|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-3693393345 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.258|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-1890575853 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.266|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-28710666 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.275|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-3452004951 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.283|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-689444492 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.294|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-2881852962 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.301|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-701952548 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.464|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-1046216858 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.473|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-2806110930 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.482|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-1418038344 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.491|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-2205968348 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.497|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-822996759 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.702|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-1611773839 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.716|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-2517169583 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.751|.\Authorization.cpp(180)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 69.34.132.56 tid=-101969781 cseq=REGISTER contact=123@1.1.1.1 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    11:20:25.757|.\Authorization.cpp(363)|Critical0|Authorization|AuthMgr::analyzeStats:Blacklisted (Too many failed auth)
    IP = 85.25.117.139; Failed auth: 25; unauth: 31; auth: 26; 407: 0<br>
    11:20:52.832|.\Call.cpp(48)|Log5||??:Currently active calls [none]<br>
    11:21:24.834|.\Call.cpp(48)|Log5||??:Currently active calls [none]<br>
