- Joined
- Jun 8, 2015
- Messages
- 5
- Reaction score
- 0
Hi all,
In the past month or so we have upgraded to 3cx v14. We are now in the process of moving the system to a dedicated box but the provisioning template we use for the yealink t38g is causing some trouble. Initially I assumed that the configuration layout had changed and began the process of updating the new version with some of the old changes. However, I have run into an issue configuring the linekeys. When using %%Line%% (Taken straight from the 3cx support page) I get the following error:
Here is what the config looks like:
I have also attempted to remove the if/else statements because in the newer template it did not show them by default. Any help with this issue would be greatly appreciated. Thanks in advance
Code:
{IF blf20}
#Configure Linekey1
linekey.1.line = %%Line%%
linekey.1.value = %%blf20%%
linekey.1.pickup_value = %%PickupValue%%
linekey.1.type = %%DKtype%%
linekey.1.xml_phonebook =
linekey.1.label = Hold 1
{ELSE}
linekey.1.type = NA
{ENDIF}
