Unpark from 3CX phone with auto answer
Discussion in 'Ideas' started by datamerge, Aug 23, 2016.
  1. datamerge
    datamerge New Member
    Nov 19, 2014
    181
    25
    Currently, when a call is unparked in 3CX phone (right click on call, select unpark) it rings the phone. This happens to physical handsets in CTI mode and also in softphone mode.
    When Unpark is selected, it would be desirable for the handset to auto answer the call. This saves a step and also creates a "hands off" operation on the phone. The phones can do it (intercom is done this way), so I imagine it would not be difficult.
    Cheers
    Mark
