Unpark with myPhone problem
Discussion in '3CX Phone System - General' started by beaterku, Jul 16, 2012.
  1. beaterku
    Dec 16, 2010
    42
    Good afternoon all,
    I am having a situation with unparking a call from a shared parking space. When I call comes in, a user parks the call with myphone in a shared parking spot. Now when anyone else in the office tries to unpark the call, they are not able to. They cannot right click to unpark. The person who parked the call is able to unpark, but no one else. Any ideas?
    Ver 11 8 user
    Cisco SPA phones
    Thanks!
    Nick
  2. beaterku
    Dec 16, 2010
    42
    Here is an example log of the situation at hand.
    A key to my log.
    pbx_internal_ip = the ip of my pbx machine
    gateway_internal_ip = ip address of my grandstream gateway
    outside_number_dialed = the number I dialed out from my desk phone
    main_office_phone_# = my main business phone number (this is what is getting me, why is this even in here? Ln10003 is tied to this phone number, is this why it is showing up here?)
    Code:
    16-07-2012 15:16:14.623   Leg L:4.3[ParkOrb] is terminated: Cause: 200 BYE from PBX
    16-07-2012 15:16:14.622   [CM503008]: Call(C:4): Call is terminated
    16-07-2012 15:16:14.621   Leg L:4.2[Line:10003>>outside_number_dialed] is terminated: Cause: 200 BYE "SIP"  from gateway_internal_ip:5060
    16-07-2012 15:15:43.857   Currently active calls - 1: [4]
    16-07-2012 15:15:11.856   Currently active calls - 1: [4]
    16-07-2012 15:15:08.817   Leg L:4.1[Extn] is terminated: Cause: 200 BYE from PBX
    16-07-2012 15:15:08.817   [CM503007]: Call(C:4): ParkOrb:SP0 has joined, contact <sip:SP0@127.0.0.1:40000>
    16-07-2012 15:15:08.659   [CM503025]: Call(C:4): Calling T:ParkOrb:SP0@[Dev:sip:SP0@127.0.0.1:40000;rinstance=0918861845b787b9]
    16-07-2012 15:15:08.649   [CM503027]: Call(C:4): From: Line:10003>>outside_number_dialed ("Nick" <sip:main_office_phone_#@pbx_internal_ip:5060>)  to  T:ParkOrb:SP0@[Dev:sip:SP0@127.0.0.1:40000;rinstance=0918861845b787b9]
    16-07-2012 15:15:08.649   [CM503004]: Call(C:4): Route 1: T:ParkOrb:SP0@[Dev:sip:SP0@127.0.0.1:40000;rinstance=0918861845b787b9]
    16-07-2012 15:14:51.571   [CM503007]: Call(C:4): Line:10003>>outside_number_dialed has joined, contact <sip:10003@gateway_internal_ip:5064>
    16-07-2012 15:14:51.570   [CM503007]: Call(C:4): Extn:102 has joined, contact <sip:102@192.168.1.150:5060>
    16-07-2012 15:14:51.547   [CM505002]: Gateway:[Grandstream_GXW4104] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 1.0, Ch:10) 1.3.4.10] PBX contact: [sip:10003@pbx_internal_ip:5060]
    16-07-2012 15:14:48.051   [CM503025]: Call(C:4): Calling T:Line:10003>>outside_number_dialed@[Dev:sip:10003@gateway_internal_ip:5064;transport=udp,Dev:sip:10001@gateway_internal_ip:5060;transport=udp,Dev:sip:10002@gateway_internal_ip:5062;transport=udp]
    16-07-2012 15:14:47.998   [CM503027]: Call(C:4): From: Extn:102 ("Nick McCord" <sip:102@pbx_internal_ip:5060>)  to  T:Line:10003>>outside_number_dialed@[Dev:sip:10003@gateway_internal_ip:5064;transport=udp,Dev:sip:10001@gateway_internal_ip:5060;transport=udp,Dev:sip:10002@gateway_internal_ip:5062;transport=udp]
    16-07-2012 15:14:47.998   [CM503004]: Call(C:4): Route 1: T:Line:10003>>outside_number_dialed@[Dev:sip:10003@gateway_internal_ip:5064;transport=udp,Dev:sip:10001@gateway_internal_ip:5060;transport=udp,Dev:sip:10002@gateway_internal_ip:5062;transport=udp]
    16-07-2012 15:14:47.996   [CM503001]: Call(C:4): Incoming call from Extn:102 to <sip:outside_number_dialed@pbx_internal_ip:5060>
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    303
    This does seem to be the case indeed.
    However if the user is an Admin of a group they should be able to (there is an option 'Can unpark all calls').
    And lower down under 'User rights' is an option 'Can unpark all calls' but you have to check several other boxes to get there, such as 'See call details' and 'Perform operations'.
    With a small office of 8, this should be feasible. But in a larger office like mine of 60... I am not sure we want group members having all these rights.
  4. beaterku
    Dec 16, 2010
    42
    Well that was it. In V9, I never used groups because there were not necessary with the assistant. I created a group for all of my extensions and boom, it works.
    Thank you very much!!
    Nick
  5. craigreilly
    Feb 1, 2012
    3,575
    303
    be careful with this. it looks as if everyone can now also transfer and disconnect a live call that is not theirs.
    it would be nice if we could check the option to unpark all calls but not give the ability to divert, transfer and take a call as well.
  6. beaterku
    Dec 16, 2010
    42
    It is small family office that half of the users wouldn't know how to do any mischief with this system.
    Thank you for your help!
  7. craigreilly
    Feb 1, 2012
    3,575
    303
    my pleasure.
