Solved Unregister Public IP from previous installation
Discussion in '3CX Phone System - General' started by Joseph Cruz, May 28, 2017.
  1. Joseph Cruz
    May 28, 2017
    I have a problem. I installed the 3CX Phone system with my public IP. in my mac justin VMWare. The installation finished successfully but I never could connect to my management console. I thought maybe could be a problem with my network configuration in the VMWare virtual machine. For that reason a create a new VM and reinstall. I use a new hostname but obviously im using the same Public IP. When the installation finished Successfully again i get one again the same url as in the previous installation. I don't know if this is generated for the use of the same IP. Some one knows if there is a way to unregister or do something with my IP to install a new 3CX Phone system with a new host but using my previously registered IP.
  2. Joseph Cruz
    May 28, 2017
    Problem Solved!
