Unregister when making outbound call
Discussion in '3CX Phone System - General' started by Pete-TPP, Jan 28, 2007.
  1. Pete-TPP
    Dec 31, 2006
    24
    I cannot recieve inbound calls all the time. Sometime they work sometime they don
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    It's a known bug of line status display. Line is still registered, but its status is not displayed correctly.
  3. Pete-TPP
    Dec 31, 2006
    24
    Thank you for your reply. Buit the connection is gone as well. When I place an inbound call the phone, on which I'm making the call, does ring but does not come trough the system and the pbx phones do not ring. Untill I restart the 3cx pbx. Is it aslo that the status of the phones is constantly idle in stead of on hook for the phones?
  4. Pete-TPP
    Dec 31, 2006
    24
    no one who knows
    Is there no one who knows the answer to my question
