Unregistered Extension
Discussion in '3CX Phone System - General' started by Mike C, Nov 20, 2017.
  1. Mike C
    Nov 14, 2017
    10
    We are receiving the below listed message on our 3cx event log. This is happening on all ip phone extensions. Any thoughts
    Extension 01 is unregistered, removed contact: sip:01@127.0.0.1:50195;transport=TCP;rinstance=0-nuu-hildvyhg.1-xgrrc5vjzyef.nssi;ob;inst="23E354"
  2. eddv123
    eddv123 Active Member
    Aug 15, 2017
    914
    139
    Hi Mike C,
    I think more investigation and explanation required here. Can you tell us are all these phones local to the 3CX System ? what phone model and firmware version are they running, can you explain your network topology in detail ?
    The only other time I recall such an output was with the 3CX client for IOS/Android trying to connect locally to the 3CX system.
    It maybe worth confirming if you have changed your local LAN IP address after install (or whether you have it allocated via DHCP) - just an idea.
  3. Mike C
    Nov 14, 2017
    10
    These phones are not local. The 3CX server is held at a Data Center. We are using SPA 504g and 525g2 ip phones with current firmware. Verified the correct IP. Thanks
  4. Mike C
    Nov 14, 2017
    10
    We continue to have this error in our 3cx logs: Interestingly, we did a new install in Google Cloud (previous install was in a data center) and we are still getting this error even with no data restored or inputted. No soft or ip phones, no sip trunk, no rules, no extensions, nothing. By default, the new install assigns user 00.
    11/22/2017 11:22:49 AM
    SIP Server/Call Manager ID: 4101
    Extension 00 is registered, contact: sip:00@127.0.0.1:5488;rinstance=b8d02958799217ca
    11/22/2017 11:22:45 AM
    Extension 00 is unregistered, removed contact: sip:00@127.0.0.1:50195;transport=TCP;rinstance=0-m9poqqlvo6goujtocazaz4v6cmg71fa4;ob;inst="083CDE"
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    Hello @Mike C
    What you are seeing is not necessarily a bad thing as devices and extensions re-register in timely intervals. Even system extensions re-register if services are restarted. Are you experiencing any issues with extensions not being registered or calls being missed?
