Unsuccessful on Windows Home Server Vail
Discussion in '3CX Phone System - General' started by zaliis, Oct 20, 2010.
  1. zaliis
    Oct 20, 2010
    I wanted to test out the free version of 3CX on Vail. Its is a 64 bit OS based on Windows 2008 R2 but It will not install I get the following error.
    3CXPhoneSystem9.exe is not a valid Win32 application. I also cannot get this to install under Windows 7 Pro 64 bit. I get the same error.
    Any suggestions or ideas?
  2. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    Sorry to be sarcastic but maybe try it out on one of the 3CX supported Microsoft Operating Systems and not one that's in beta ?.
  3. zaliis
    Oct 20, 2010
    I had to download and install the software from deerfield.com and then everything worked as expected. So I suspect that the version that I download from 3cX.com has problems. Oh and since Vail is based off of Windows 2008 server R2 the software is supported.
  4. danoh
    Aug 18, 2010
    56
    XP Media Center is based off of XP Pro, but that doesn't make it a supported OS for 3CX....
  5. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,455
    92
    You most probably got a corrupted/interrupted download.
    Try downloading the phonesystem again and see what happens.
