unsupported media error
Discussion in 'Windows' started by amygoda, Sep 29, 2011.
  1. amygoda
    amygoda Member
    Sep 18, 2006
    436
    when I try to call ext. on planet fxs device it gives me "unsupported media "
    13:03:19.656 [CM503016]: Call(21): Attempt to reach <sip:70201@10.99.99.201:5060> failed. Reason: Not Acceptable HereReason Unknown
    13:03:19.656 [CM503003]: Call(21): Call to sip:70201@10.99.99.201 has failed; Cause: 488 Not Acceptable Here; from IP:10.99.99.111:5060
    13:03:19.484 [CM503025]: Call(21): Calling Ext:Ext.70201@[Dev:sip:70201@10.99.99.111:5060]
    13:03:19.484 [MS210006] C:21.2:Offer provided. Connection(by pass mode): 10.0.0.93:40042(40043)
    13:03:19.453 [CM503004]: Call(21): Route 1: Ext:Ext.70201@[Dev:sip:70201@10.99.99.111:5060]
    13:03:19.453 [CM503010]: Making route(s) to <sip:70201@10.99.99.201:5060>
    13:03:19.453 [MS210000] C:21.1:Offer received. RTP connection: 10.0.0.93:40042(40043)
    13:03:19.437 Remote SDP is set for legC:21.1
    13:03:19.437 [CM505001]: Ext.70777: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.20943.0] PBX contact: [sip:70777@10.99.99.201:5060]
    13:03:19.437 [CM503001]: Call(21): Incoming call from Ext.70777 to <sip:70201@10.99.99.201:5060>
    13:03:19.421 [CM500002]: Info on incoming INVITE:
    INVITE sip:70201@10.99.99.201:5060 SIP/2.0
    Via: SIP/2.0/UDP 10.0.0.93:1039;branch=z9hG4bK-d8754z-507cbc5ddb515b42-1---d8754z-;rport=1039
    Max-Forwards: 70
    Contact: <sip:70777@10.0.0.93:1039;rinstance=70e82d4156c3c726>
    To: <sip:70201@10.99.99.201:5060>
    From: "admin"<sip:70777@10.99.99.201:5060>;tag=bd4cdc78
    Call-ID: MDVlZGM0MmRmZTQ5MGNmOTJlZTVmYWM1MjIzNDYyZmE.
    CSeq: 2 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    Proxy-Authorization: Digest username="70777",realm="3CXPhoneSystem",nonce="414d535c0494d36792:cfefbe4796345dc6a2c3533d9b7cb9b1",uri="sip:70201@10.99.99.201:5060",response="edca5ff3407813c2115bcd8f0bc185f3",algorithm=MD5
    Supported: replaces
    User-Agent: 3CXPhone 6.0.20943.0
    Content-Length: 0
    10,368
    229
    That generally means that there is a problem with the Codecs you are trying to use.
  3. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Thank You
    it solved by pbx deliver audio or record all calls
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    It means that this device is not completely compliant to RFC3264
    3CX Phone offers audio and video media (video media can be disabled in phone configuration).
    In any case, device should not reject offer completely, it should simply reject video media and continue with audio.
