unsupported media
Discussion in 'Windows' started by tayling, May 15, 2013.
  1. tayling
    May 15, 2013
    I have successfully set up installed an account and works great - on setting up another - I get the error when dialling
    unsupported media
    Any help gratefully recieved
    Regards
    Tony
    10,570
    247
    Sounds like a Codec issue. Be sure that the Codec that you are trying to use is supported.
  3. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    I found that Broadvox will hate your call if you do not disable video on the VoIP provider config.. as an example.
    When we work from home/remote and fire up 3CX Phone for Windows, we use webcam capability.
    Nexvortex did not seem to care.. though the calls would not negotiate video anyway on external calls (not that I cared..).
