Unsupported Phone Configuration - Cisco 6921 & 6961
Discussion in '3CX Phone System - General' started by qsjam, Nov 9, 2014.
  1. qsjam
    Oct 26, 2014
    8
    I understand by viewing previous posts on here that its possible to use phones that are not officially supported.
    I assume this would involve getting a copy of the necessary configuration files for the phone, modifying them manually with your server & extension settings then uploading them to the phone.
    I'm particularly interested in the Cisco 6921 & 6961 which I see have web-based configuration.
    Many Thanks for any opinions on the topic!
    10,848
    299
    If the sets have SIP firmware installed, and they have "web-based configuration", which I assume means a GUI, then you should be fairly straight forward to configure without having to up load a configuration file.
    If a config file(s) is required, you may have some luck doing an on-line search for some "generic" examples for those models, that you can then modify.
  3. qsjam
    Oct 26, 2014
    8
    Thanks again lee, I have picked a couple of sets up quite cheap on ebay so I'm gonna have a go.
  4. leejor
    10,848
    299
    You're probably not the first to attempt this. Do some searches, and check the Cisco forum.
