Solved Unsupported Point to Point configuration
Discussion in '3CX Phone System - General' started by Lance Lavery, Jul 12, 2018.
  1. Lance Lavery
    Mar 14, 2018
    12
    Hi all,
    I know this is an unsupported configuration, but has anyone been able to force their sip traffic between 2 fiber connected LAN's? I find it very stupid that I must send my calls between offices out over the internet when I have a better connection available. And before I get bombarded with 2 offices 2 PBX's ETC.. Our staff moves between offices on almost a daily basis, so 2 VM boxes, 2 Ext numbers will not work for us.
    We have never had an issue before with Asterisk, FreePBX or Zultys. So I cant figure out why I cant get this to work.
    I've tried, no SBC- direct routes, With SBC, all sorts of different rules forcing traffic from one LAN to the other, but with no luck.
    So anyone have any ideas??
    [​IMG]
    Lance
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,211
    191
    On the two networks 192.168.1.0 and 192.168.2.0, can you access remote devices from one network and the other way round - the two networks are fully open using your private connection
    On the 192.168.2.0, configure dhcp option 66 to point your 3CX server https://www.3cx.com/sip-phones/dhcp-option-66/
    Configure the phones as local lan within the 3CX management console - select IP address or fqdn on the interface. (if you select fqdn, make sure that 192.168.2.0 network can resolve the fqdn back to the 3cx ip address). This is spilt DNS https://www.3cx.com/docs/creating-fqdn-split-dns/
    Info on configuring phones - https://www.3cx.com/sip-phones/
    Routing of traffic is done by your network devices and not 3CX.
  3. Lance Lavery
    Mar 14, 2018
    12
    Thanks for the info, I will try this over the weekend.
    Lance
  4. Lance Lavery
    Mar 14, 2018
    12
    As a follow up to this.. This was not the solution.
    In my case, I needed to manually add a route to the second office subnet inside my Patton SmartNode 4970. Since the original config file for the Patton was generated by the 3CX and it did not provide that information automatically.
    Problem solved.
    Lance
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,890
    495
    Glad to see the issue has been resolved and thank you for updating the thread with your solution.
