Unsupported sip phone - Aastra 9143i
Discussion in 'Windows' started by cbroessel, May 9, 2013.
  1. cbroessel
    May 9, 2013
    6
    I have a stockpile of 9143i phones. i would like to use them on my first 3cx install - an inhouse system for me to demo and for practice for the certification test. i have it connected and its recieving calls, but nothing goes out - i cant call vm or other exts. i'm pretty sure i have my phone set up properly, i'm just wondering if maybe i don't have the model right in the provisioning screen. but as its not an option, i'm not sure what to select for the model. any advice? thanks
    chris
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    this is in the soft phone forum so may not get a ton of replies...
    do you see anything in the Log Files of 3cx server when making the call?
  3. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,773
    278
    Hey Chris,
    If you are just using it for testing, then I would just manually provision the phone per the following guide:
    http://www.3cx.com/sip-phones/aastra/
    If you are planning on doing a large deployment, then you would be best served to manually configure a single phone and then dump the config out, and then copy that per phone in the provisioning folder, making the necessary changes. Or you could try your hand at making a custom template.
