Unwanted TLSv1 to SIP Provider
Discussion in '3CX Phone System - General' started by Michael Moore, Feb 28, 2018.
  1. Michael Moore
    Aug 2, 2017
    8
    I have an IP authenticated SIP trunk setup between our 3CX and Fusion. They did a capture related to a different issue we were having an were seeing a lot of TLSv1 handshake requests coming from us. I'm trying to figure out how to turn off the secure SIP option for this SIP trunk since it's not supported by the provider.
    You can see in the attached screenshot the packets I'm talking about circled. I've deleted the IP's but one is our 3CX and the other is the ITSP's SIP server.
    Any help would be great.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
  3. Michael Moore
    Aug 2, 2017
    8
    In that reply someone says you can:
    "If they support SIP over TCP you can prepend transport-tcp. to your registrar and force the PBX to use TCP to communicate to the provider."
    How do you do that? If I can force the 3CX to do that instead of try and connect via TLS that would solve my issue.
  4. YiannisH_3CX
    May 10, 2016
    6,016
    421
    This is what is described in the thread. You need to prepend " transport-tcp." to your registrar to force the trunk to register with TCP instead of TLS
    Edit you trunk and adjust the registrar field by prepending " transport-tcp." upload_2018-3-2_11-56-1.png
