Solved Update failure
Discussion in '3CX Phone System - General' started by rvoosterhout, May 24, 2017.
  1. rvoosterhout
    May 24, 2017
    47
    Hi Everybody.
    This is my first post, so I hope it's ok that I ask this question here. I recently reinstalled my 3cx server, because i had some problems with the 3cx clients not showing a presence and complaining about a API connection. After the re-installation, all the clients work normal again, but I can't update my 3cx anymore.
    I read the log file, but I don't see what goes wrong. At line 2312, there is an error code which has something to do with it I think.
    Thanks in advance!
  2. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    What version are you running at the moment?
  3. rvoosterhout
    May 24, 2017
    47
  4. rvoosterhout
    May 24, 2017
    47
    and i want to update to 15.0.62928.5
  5. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    This is a different case. Restart all services and try again.
    Maybe there is some corrupt download.
    If you don't manage send me a pm and I will contact you and we will fix this remotely.
    Lets close this quick because we are going to be very busy with the final.
  6. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    put the log file in the pm.
  7. rvoosterhout
    May 24, 2017
    47
    This thread can be closed. Update problem is gone after fresh install to 15.5.
