Solved Update Message Mac OS client
Discussion in '3CX Clients' started by scottcalcp, Oct 17, 2017.
  1. scottcalcp
    Aug 11, 2017
    15
    Every time I open the 3cx client for Mac it tells me to update. The things is I have already updated it.
    I am using v 15.1.079 on Mac OS 10.10.5 Yosemite.
    Anyone else having this issue?
  2. scottcalcp
    Aug 11, 2017
    15
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hello @scottcalcp
    Glad the issue is now resolved and thank you for sharing your solution.
