Update <PBXLocalAddr> After IP Change
Discussion in '3CX Phone System - General' started by moonbug88, Sep 12, 2017.
  1. moonbug88
    Apr 12, 2010
    6
    How to update the <PBXLocalAddr> after IP change?
    I read in old thread that you can force to change (update) all config files by going to Settings > Phone Provisioning, change “Enable Daylight savings time” but this menu option is gone.
    Is there another way?
  2. pact
    pact New Member
    Dec 16, 2009
    172
    31
    Which version of 3CX?
  3. moonbug88
    Apr 12, 2010
    6
  4. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    877
    135
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    The only way to ensure you have a working PBX is to perform a backup without licence and FQDN, save the backup to a non 3CX location and then un-install the system. Then re-install using the backup you created and select the correct local IP in the installer.
    If you have local extensions you will need to reprovision them
