update phonebook
Discussion in '3CX Phone System - General' started by filipvds, May 29, 2013.
  1. filipvds
    Apr 15, 2013
    33
    is there a way we can update the phonebook automatically?
    We have developped our own application and I can install the odbc driver on the 3cx server. I can also develop a little tool to create a compatible xml file (or csv file). Is it possible I can dump a file on the server and 3CX will automatically "import" the file?
    Fiilip
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    If you develop your own application then try to use "3CX Configuration and Call control" API which is available on the host of PBX server. It is much easier and reliable. Also your application will have highest possible level of compatibility with the next versions of PBX. I think that it worth to try.
    You can find documentation and examples on http://www.3cx.com/blog/docs/call-control-api/
    Regards
