No, it should be finecould there be a Problem with Upgrading from SP 2 to SP 4?
I had the same issue thanks for solving it quickly. I have another issue I am not able to add a new phone to a new extension what would be the issue.
- In file /etc/apt/sources.list.d/3cxpbx.list to have:
- Jessie: deb http://downloads-global.3cx.com/downloads/debian jessie main
- Stretch: deb http://downloads-global.3cx.com/downloads/debian stretch main
- In the Management Console --> Settings --> Parameters, edit parameter "DOWNLOADS_URL"
- https://downloads-global.3cx.com/downloads/v155
- If you have to change the value here, restart all 3CX Services, especially Management Console service, then go to Dashboard --> "Updates" button and try again.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
