Update to V15.5 failed Patton SN4114
Discussion in '3CX Phone System - General' started by Neil Pickard, Jul 28, 2017.
  1. Neil Pickard
    Jul 28, 2017
    I updated to version 15.5 last night and now my FXO gateway will not function. I have updated the SN4114 to the latest firmware version and have deleted and re-added the gateway following online instructions in 3CX with no success. Any assistance would be appreciated.
  2. Neil Pickard
    Jul 28, 2017
    The VOIP link on the Patton does nothing but flash.
  3. teldata1
    Aug 24, 2015
    63
    I would format the gateway by holding the reset switch in. Then re-add the gateway to the 3CX
  4. jbryant84
    jbryant84 New Member
    Apr 6, 2016
    108
    42
    Have you tried generating a new config file and uploading to the gateway? Sometimes templates change across service pack versions.
