Update v10 SP4 - Norton Internet Securit -Take Care-
Discussion in '3CX Phone System - General' started by SnelleEdje, Nov 8, 2011.
  1. SnelleEdje
    Nov 6, 2011
    19
    I just updated my system (v10) with the new sp4.
    My Norton Internet Securite thinks the file \users\<name>\appdata\local\temp\3cxupdates\scripts\tcxdbupdater.exe (that obviously comes with the servicepack) is a virus and will put it in quarantine. (It's not a virus of course).
    So temporary disable Norton Internet Security before updating!
    I told NIS that this file was not a virus and NIS did put it back in place. I ran it manually but I am not sure I should have done this. (Got no prompt whatsoever).
    The system seems to run okay now...
    Oh, missed a log entry. The file c:\program files\3cx phonesystem\data\db\cluster_80.exe is identified a virus as well. False positive of course.
    Regards,
    Edwin.
  2. SnelleEdje
    Nov 6, 2011
    19
    Is there a possibility to run his SP4 update a second time? I am afraid it did not completely run and a cannot install it again from the manager.
    Regards,
    Edwin.
