updates in v15, toggle non required phones from showing updates available
Discussion in 'Ideas' started by npereira@cbnco.com, Jan 23, 2017.
updates in v15, toggle non required phones from showing updates available 4.7 5 12votes
4.7/5, 12 votes
  1. npereira@cbnco.com
    Sep 21, 2012
    32
    12
    There should be a way to disable the updates for the phone we don’t have. So that it cleans up the “available updates” basically not show that there is updates for the devices we don’t have. Or else there is always a red button on the UPDATES top menu bar…Very anoying !
    media2, Taff3333, jbryant84 and 2 others like this.
  2. giwm
    giwm New Member
    Sep 27, 2016
    246
    42
    Not just phones... anything. Integrations, phone templates, whatever.
    Also, if you want to make a custom template (say one for a Yealink T46G8) you might change the original to a .bak so it doesn't pick up the wrong template. Now your original template always has an update. Ugh.
