Updating from 8 -> 9 question
Discussion in '3CX Phone System - General' started by Aho, Dec 17, 2010.
  1. Aho
    Aho
    Dec 17, 2010
    I have an install of 3cx v8.0.10824.716 I want to update it to the lastest version.
    I thought maybe I could just backup what I have, uninstall, install v9 sp5, restore and be done with it. But apparently not, since3cx prompt me to update to version 8 13357 before doing an update to 9.
    However, The download link in the updater in 3cx is ghosted. There is another link as well but that leads to a 404 error. I go to look for the version 8 build 13357 on the 3cx site and can't find it anywhere.
    I don't have a huge window to keep the system down, so I would be most grateful for some good info on what would be the most prudent thing to do.
  2. Aho
    Aho
    Dec 17, 2010
    Forgot to meantion that I do have upgrade insurance.
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Hey Aho,
    Well first off, you are seeing it gray simply because you are not accessing from the management console. If this issue peresists I advise you do the following exactly in the order I have written below.
    1. Creat a backup.
    2. Unistall 3CX version 8.
    3. Reinstall 3cx version 8 from link below.
    http://www.3cx.com/downloads/3CXPhoneSystem8.exe
    4. Resore.
    5. Backup again.
    6 Uninstall 3CX version 8 again.
    7. Download version 9 (link below).
    http://www.3cx.com/downloads/3CXPhoneSystem9.exe
    8. Install version 9.
    9. Restore Backup.
    10. Recreate forwarding rules for every extension.
    phew! hope this helps!
