Updating office hours using Chrome browser**DISCUSSION
Discussion in '3CX Phone System - General' started by carltoncl, Jul 24, 2010.
  1. carltoncl
    Dec 13, 2007
    25
    I prefer to use Google's Chrome browser. Today I was updating our office hours via the web management console on my PC using Chrome but the hours would not update. I switched to IE, no problem. So I am guessing there is some Javascript or other code that doesn't play well with Chrome.
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    408
    8
    Google chrome is not supported with 3cx. We make it very clearly in the Installer as Recommendations.
    We Supports only IE and Firefox.
    But to make you happy, try and use Google chrome plus -http://www.chromeplus.org/
    Google chrome plus can change to IE mode. So if you want to use 3cx with chrome you just need to change page to IE.
    Thanks and Regards.
