Updating SSL's Certs on Debian when using own FQDN
Discussion in '3CX Phone System - General' started by David Forster, May 15, 2017.
Tags:
  1. David Forster
    May 3, 2017
    8
    We have recently switched from Windows to Debian.
    So far so good, loving the small footprint of the server and was impressed with the install, very easy, even asked for the SSL cert pfx file during install.
    My question is around renewing the SSL cert when the time comes (in 12 months).
    I can't find anywhere in the control panel where it can be updated, am I missing something, surely if there is a procedure with 3CX to install one in the first place this procedure can be called again from the control panel upon time of renewal?
    If not what are the options / procedures for updating the SSL cert at time of expiry?
    Regards,
    David.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,509
    468
  3. David Forster
    May 3, 2017
    8
    Thanks,
    I'd found that document, however it refers to the procedure for updating the certificate on a Windows machine and my question was in regards to a Debian machine.
    Perhaps a similar document could be created to address this issue.
    Many thanks,
    David.
  4. YiannisH_3CX
    May 10, 2016
    6,509
    468
    If you take a careful look at the document it refers to the Linux path as well. The procedure is the same
    techbold and David Forster like this.
  5. David Forster
    May 3, 2017
    8
    I guessing the phrase 'should have gone to SpecSavers would be appropriate at this point. Think it was the example images that threw me off being windows.
    Many thanks,
    David.
