Upgrade 3CX to more Sim Calls
Discussion in '3CX Phone System - General' started by Roberto teste, Apr 9, 2018.
  1. Roberto teste
    Mar 21, 2018
    7
    Is it possible to upgrade my license for more Simultaneous Calls without reinstalling my 3CX?
    Thanks,
    Regards.
    Roberto.
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    942
    149
    No reinstall, you just apply your new license key
  3. V..
    V..
    Feb 14, 2017
    62
    23
    I'm afraid this is incorrect information.
    You cannot change the license key, you may be able to upgrade your current key to add additional calls, you will need to contact your reseller to discuss this.
    If you cannot upgrade your key you will need to backup your PBX making sure not to include your Key or FQDN, release your FQDN tie to your old key and restore your backup reeentering your FQDN and the new key.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,891
    321
  5. Roberto teste
    Mar 21, 2018
    7
    It was very helpfull.
    Thank you, guys!
