Upgrade Demo Account
Discussion in '3CX Phone System - General' started by Fred Pettengill, Jun 30, 2017.
  1. Fred Pettengill
    Jun 30, 2017
    6
    I have been using 3CX for a couple years on a local copy, and just tried the Cloud version on a 3CX PBX Express demo account. After playing with it a short time, I want to move from my local copy to the cloud using my current license.
    Does anyone know if you can "upgrade" the demo account to a regular cloud account? I'm not sure what cloud the demo is using, and there is nothing in the demo that suggests it can be upgraded to a permanent account by just subscribing to the cloud provider and changing the license number. I can see that maintenance expires in 30 days which would change if I changed the license number, but the demo is not on a paid cloud account?
    Thanks for the help!
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,380
    535
