Upgrade Firmware Tab in V10
Discussion in '3CX Phone System - General' started by Smac1, Apr 30, 2012.
  1. Smac1
    Apr 30, 2012
    Hello All,
    Since we just upgraded to 3Cx V10. I would like to use the Upgrade Firmware version phone in 3cx.
    I have downloaded and imported as per step in 3cx. It did upgrade the first Snom 870 Phone to downloaded version, But when I do it for next phone or in group (same Snom 870) it restarts the phone but does not upgrade.
    Is there anything more need to be done?
    My Snom Phones are on version Snom870/8.4.32
    I would like to upgrade to Snom870/8.4.34
    3cx System version V10.0.24018.2322 SP6
    Regards,
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    Check if phones are autoprovisioned wit 3cx. If Yes, than the firmware that you are trying to update is the same as the existing one.
