Upgrade from 9 to 10 with Server Change
Discussion in '3CX Phone System - General' started by roycruse, Apr 26, 2012.
  1. roycruse
    Apr 23, 2010
    8
    I am about to move my 3CX Enterprise system from a temporary server to its new home on another server.
    I also want to upgrade from version 9 to version 10
    Should I :-
    1. upgrade to version 10 on the old server then install version 10 on the new server and restore a backup from old pc to new.
    2. install version 9 on the new server then restore from old to new then upgrade on the new server.
    3. can i install version 10 on the new server and restore a version 9 database and upgrade the database on the new server.
    or have i got to do something else...
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    I would use the backup restore tool and backup your current settings, install v10 on the new server and restore the settings from version 9 and you should be good to go. I say should as it is simple as that you never know what can go wrong, but it should be straightforward and simple. good luck!
  3. roycruse
    Apr 23, 2010
    8
    Yes that worked fine - thank you.
    only problem I had was I installed the 3cx software and restored the backup whilst the other server was still running.
    when I turned the old server off and switched the ip address of the new server to the correct one. lots of occurrences of the old IP lingered on in settings and ini files.
  4. jpillow
    Jun 20, 2011
    1,342
    Which is exactly why I said "should" be as simple as that :) , I've had multiple IP address issues when going to a new server data cutovers, new router cutovers etc.... There is really no way around it other than planning ahead, quick thinking during the cutover,, and a small bit of praying. I'm glad it worked out well for you.
