Upgrade from v12 to v14
Discussion in '3CX Phone System - General' started by ETAU, Jan 14, 2016.
  1. ETAU
    Feb 4, 2014
    17
    Can you upgrade directly from v12 to v14 or do you need to upgrade via 12.5?
  2. nikosT_3cx
    3CX Support
    Jun 2, 2014
    57
    yes you may but only if the Phone System is at least on version 12 SP6.1 as per manual.
    If it is not then the restore will not work.
    Please check the following link : http://www.3cx.com/docs/installing-3cx/#h.tbfd451mjmli
  3. adrianc
    Sep 4, 2015
    20
    I tried a couple of clients from 12 to 14 and it failed to restore the config file both times (12 was patched to the latest) but have had no problems going 12 to 12.5 then to 14. That's worked every time although a number of settings don't appear to be taken over, such as country codes blocked.
  4. complex1
    complex1 Active Member
    Jan 25, 2010
    813
    46
    I agree with this. This is also my experience.
  5. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Same.
    Aside, I've had rather odd ghosts in the shell post-upgrade. At times I've resorted to a rebuild using the same info if small enough.. getting a good backup to start with.
