Upgrade from v14 to 15.5 - Yealink T48G BLF show DND users as green
Discussion in '3CX Phone System - General' started by Dunec, Feb 2, 2018.
  1. Dunec
    Feb 15, 2017
    Recently updated 3CX, and receptionist is seeing a change where when an extension is in DND, it is no longer red on the BLF key, but green. If using the 3CX app, the status is color coded correctly, but they are resistant to change. How can I change the template to recreate the v14 behavior?
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,099
    166
    Make sure your license has been applied correctly.
    The phones are running the latest support 3CX firmware
    The latest templates for the T48G has also been downloaded and pushed out
  3. Dunec
    Feb 15, 2017
    Yes, Yes, and Yes
  4. complex1
    complex1 Active Member
    Jan 25, 2010
    788
    45
    There is no DND indicator available on the phone.
    Take a look on page 9 of the T4 Series User Guide V82.20 - Icon indicators (associated with BLF/BLF List)
    YiannisH_3CX and Dunec like this.
