Upgrade from v14 to v15 and keep the same provisioning path
Discussion in '3CX Phone System - General' started by mantalope, Jan 13, 2017.
  1. mantalope
    Mar 10, 2011
    35
    I want to update my 3CX system from v14 to v15 but need to keep our provisioning path the same so I won't need to update the provisioning profile rule all of our remote Cisco 504G phones.
    In the past, updating the version and restoring the backup seemed to change the provision folder location. Is there a way to keep the provisioning folder the same after restoring the data on the updated v15 system?
    Or, once the update/restore is complete, can I just change the "PROVISIONING_FOLDER" parameter (and move/rename files as required) to keep the provisioning profile path the same?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello there,
    I believe your issue will be greater that the provisioning folder as in V15 cisco SPA phones are not supported as remote extensions. Cisco phones do not support Https connections and v15 web server does not accept Http connections from remote locations. As for the provisioning path i would recommend not changing it from the custom parameters as this may cause additional issues with provisioning.
  3. mantalope
    Mar 10, 2011
    35
    Thanks for the reply. I did not realize the Cisco SPA limitation. I think I'll stick with v14 for now.
