Upgrade from V15 Free to V15 Pro - how?
Discussion in '3CX Phone System - General' started by adminbod, Aug 18, 2016.
  1. adminbod
    Jan 18, 2010
    36
    Been running V15 Free for a while now, and want to upgrade this to PRO...
    How do you do this? - I can't see anywhere to enter the new license key?
    cheers...
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    If you have bought a different license key from the one that you have installed on the PBX then you need to take a backup without the License key information uninstall the PBX and re-install with the correct key.
    Note that before you re-install you will need to login in to the ERP https://erp.3cx.com with the credential you have in the email you received at the initial install and release the previous key from the FQDN.
    If you upgraded the free key then all you have to do is click on the license Tab in the information section of the management console then click edit and ok without changing anything and your upgrade will be applied.
  3. adminbod
    Jan 18, 2010
    36
    Thanks - I upgraded the free key, so your second suggestion worked...
