Upgrade from V9 to V10?
Discussion in '3CX Phone System - General' started by cgallery, Sep 19, 2011.
  1. cgallery
    Dec 6, 2010
    40
    I'm using the free edition of V9 now. I found out the problems I've having with Sangoma provisioning is related to the fact that I'm following instructions for V10, but I'm using V9.
    So can I simply backup my V9 config, upgrade to V10, and reload my config? Will I ever need to reload my config (I'll backup anyhow). Any notes around for doing upgrades?
    TIA
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Upgrading is easy, do a backup uninstall V9 but make sure V9 is up to date meaning SP5. Then install V10 and restore your backup. Everything should work as planned.
    Thanks,
    Nate
