Upgrade issues.
Discussion in '3CX Phone System - General' started by wzaatar, Dec 9, 2008.
  1. wzaatar
    Aug 1, 2007
    90
    Hello 3cx people!
    I upgraded from 6.1 to 7.0, upgrade went --apparently-- smooth, backed up my config, uninstalled, installed the new version and restored my config... And a problem arises...
    Seems that the 3cxphonesystem.ini file is not properly restored or some sections are not there cause my old [Network] containing the LocalSubnets is not there, and 3cx is proxying my connections now!
    I added the section, restarted the server... Nothing changed. Still in Proxy mode...
    Now, can someone please tell me how to fix this in the new version?
    Thanks,
    W.
  2. wzaatar
    Aug 1, 2007
    90
    Hello, everyone.
    Would anyone please confirm if he/she got this issue resolved in v7?
    Thank you,
    Wadih
  3. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    If I follow your post correctly you had made changes to your INI file. If this is the case can you please confirm what changes you had made and the reason for the change. We can then advise how best to fix / address.
  4. wzaatar
    Aug 1, 2007
    90
    Hi William,
    Again, thanks for the prompt reply.
    A specific change that I made is a localsubnets modification line I added, without it the PBX cannot accurately resolve my internal subnets in case I'm using non-standard subnetting or non-contiguous subnets.
    Cheers,
    W.
  5. William400
    Aug 21, 2006
    1,005
    Re-adding your customizations to the INI file and restrating the 3CX Phonesystem and DB service should put you back in place.
