Solved upgrade license 3cx standard
Discussion in '3CX Phone System - General' started by rizqi randhani, May 8, 2017.
  1. rizqi randhani
    May 8, 2017
    Dear Team,
    I have bought license upgrade 3cx standard from 64sc to 128 sc.
    recently, when i check in license setting menu, the numbers of Simultaneous Calls already change to 128, but in PABX status still show as 64 sc.
    how to implement it ?
    vendor haven't give new license key for upgrade 128sc, but still using previous key.
    Best Regards,
    Rizqi
  2. rizqi randhani
    May 8, 2017
    FYI,
    My 3CX system is version 15.0.0
  3. GiannosC_3CX
    GiannosC_3CX Guest
    Hi rizqi randhani,
    Please try the below steps and let us know if it works for you.
    Go to Management console > Information > License > License Settings > Edit > OK.
  4. rizqi randhani
    May 8, 2017
    Hi GiannosC_3CX,
    Great, It works, many thanks :)
