Upgrade problems
Discussion in '3CX Phone System - General' started by ViperBorg, Jun 25, 2008.
  1. ViperBorg
    Jun 25, 2008
    7
    Upgraded to lastest version of 6, now my username and password don't work. What are the defaults?!
    admin
    admin
    Doesn't work
  2. darrellchapman
    Nov 26, 2007
    268
    Can you do a restore from backup using the new included backup/restore utility?
  3. Nebula
    Nebula New Member
    Apr 6, 2008
    116
    What version did you upgrade from? If v6.xxxxxx it should have retained your old password. If you upgrade from V5.xxxx you need to uninstall this first.
    I don't believe there is a default username and password, you set these when you install, I'm sure someone will jump in if I'm wrong here.
