Upgrade procedure**MAJOR VERSIONS REQUIRE UNINSTALL
Discussion in '3CX Phone System - General' started by barnum, May 11, 2011.
  1. barnum
    Sep 17, 2007
    Will the update procedure available into the update list or will be necessary to backup and restore from previous installation?
  2. nb
    nb Support Team
    Jun 7, 2007
    2,117
    145
    Re: Upgrade procedure
    If you are referring from moving from v9 to v10, these are major versions therefore the procedure is needed to backup, uninstall, reinstall, restore.
    Between Version 10 updates then we will proceed with Service packs.
