Upgrade to 15.5 SP2 failure
Discussion in '3CX Phone System - General' started by AKn, Feb 23, 2018.
  1. AKn
    AKn
    Feb 23, 2018
    Hi all,
    Getting:
    ERROR: ExecuteScript returns FAIL: Npgsql.PostgresException (0x80004005): 23505: duplicate key value violates unique constraint "parameter_name_key"
    During the database script it appears....Any suggestions or ideas?
    TIA
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,094
    165
    What version are you upgrading from ?
  3. AKn
    AKn
    Feb 23, 2018
    15.5.3849.1 --> 15.5.6354.2
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    Hello @AKn
    This error usually appears when you downgraded the PBX using a backup from a higher version and then tried to upgrade again. Did that happen in any of the previous service packs?
  5. AKn
    AKn
    Feb 23, 2018
    I had to change my license, it is exactly that situation!
  6. YiannisH_3CX
    May 10, 2016
    6,016
    420
    I am afraid that you will need to open a ticket with our support department so they can see what parameter is giving this error and help you correct it. For now you can re-install your backup to 15.5.3849.1 so that you have a working PBX.
