Upgrade to latest 3cx v8
Discussion in '3CX Phone System - General' started by targeted, Jun 17, 2010.
  1. targeted
    Feb 11, 2010
    11
    I wish to upgrade from v8.0.9532.468 to the latest version v8.0.10x.
    The upgrade facility within 3cx show me that the newer version exists but, doesn't allow me to download it. If I try to do it manually then I am advised to uninstall the existing version before installing the latest one.
    Is there a correct way of doing this?
    I thought using the upgrade facility would be the right thing to do, now I'm not sure.
    Any guidance on this please.
  2. carolinainnovative
    May 4, 2009
    369
    6
    Using the update facility - have you tried it from the WIndows Management Console on the machine itself instead of over the web?
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Simply take a backup of the system, uninstall and install the latest version, when it asks you to for your old backup comply and your done.
