upgrade to Pro or Ent.
Discussion in '3CX Phone System - General' started by Mazen Shennar, Mar 14, 2018.
  1. Mazen Shennar
    Mar 6, 2018
    Hallo,
    How can I change the existing 3CX Free standard edition to Pro. or Enterprise edition?
    I mean is it possible to avoid performing the long process of removing the old one and installing the new one? Unknowing that I am using 3CX V15.5
    Thanks in advance
    Regards
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,358
    535
    Hello @Mazen Shennar
    Please note that you can upgrade your current key to a Pro or Ent. edition by contacting your reseller or online from here without the need to re-install.
  3. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    893
    154
    It's as simple as upgrading your key.
  4. Mazen Shennar
    Mar 6, 2018
    thanks for for your advice
  5. YiannisH_3CX
    May 10, 2016
    7,358
    535
    Glad i could assist.
