Upgrade to v12.5 from V11
Discussion in '3CX Phone System - General' started by eeknz, Jan 28, 2015.
  1. eeknz
    Jun 8, 2012
    Is the 11 > 12.5 migration a one step upgrade, or do I have to go 11 > 12 > 12.5?
    Andrew
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi there,
    Kindly note that you'll have to :
    - ensure you are running latest service pack for v11 (sp4A),
    - backup,
    - uninstall 3cx phone system,
    - install v12 (from our website you'll get latest version with sp6.1),
    - restore
    - backup on 12,
    - uninstall,
    - install 12.5
    - restore latest backup.
  3. Patch1
    Jun 29, 2013
    12
    I'm intending to do the same. I have current maintenance.
    Where do I download v12 from?
    Edit:
    Never mind I guessed from the v11 update offer post, but for others these worked for me
    downloads.3cx.com/downloads/3CXPhoneSystem11.exe
    downloads.3cx.com/downloads/3CXPhoneSystem12.exe
  4. Patch1
    Jun 29, 2013
    12
    I had a look at the upgrade instruction
    http://www.3cx.com/blog/docs/upgrade-3cx-phone-system/
    http://www.3cx.com/manual/3CXPhoneSystemManual12.pdf
    http://www.3cx.com/manual/3CXPhoneSystemManual125.pdf
    but was still unsure about a couple of things
    Just to clarify.
    Is the purpose of installing v12 just to convert a v11 backup to a v12 backup? If so can I just do it on a test rig not connected to my usual phone network?
    Do I need to update the MyPhone client on all computers while running v12 or can I wait and do that once with v12.5?
    Do I need to configure features new to v12 like "Extension Management Permissions", "Extension Groups" etc or can that all wait to v12.5?
  5. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    832
    126
    @Patch1
    - Yes the purpose up installing v12 is just to convert a v11 backup to v12 backup. Theoretically you can do it anywhere, but I've always done it 'in-place'
    - The v12/v125 MyPhone is a completely re-written client, there is no upgrade. So you would deploy the client via the welcome email in v125 and you will need to remove the old v11 client manually.
    - You can wait till you get on v125 for the Extension Management stuff. It will just default everyone in the same group/permissions
