Upgrade to v15 - Multiple trunks
Discussion in '3CX Phone System - General' started by geertv, Mar 27, 2017.
  1. geertv
    Jun 13, 2011
    I am running 3CX v14 Free at home, only for internal communications.
    I would like to upgrade to the new version, but it seems there are limits on SIP trunks (only 1).
    I have 3 doorphones which act as a SIP server, so normally you can directly connect from a SIP client. In order to have some extra functionality i configured this doorphones as SIP trunk only allowing inbound calls. This is working perfect for me.
    Will this still work after upgrade ?
    Are there any other solution ?
    Many thanks,
    Geert
    11,109
    329
    Given that 15 only supports1 trunk (without a licence), you may have to change the door phones to register with 3CX, as extensions.
    or...don't upgrade.
  3. AlexDBarrett
    Jan 25, 2011
    71
    9
    You will also need to purchase a licence after 12 months as the fqdn will expire, assuming you use the free 3CX one.
    Alternatively reinstall every 12 months.
