Upgrade to V15 - several Yealink T48G phones fail to register
Discussion in '3CX Phone System - General' started by dean@insurewithstarr.com, Feb 27, 2017.
  1. dean@insurewithstarr.com
    Aug 1, 2016
    We upgraded from V12 (full backup) to V15 install using backup file for configuration.
    We have 25 Yealink T48G phones and about half of them needed the firmware updated. Upon doing so, 8 of them would not register. Did a factory reset, deleted the phones from the extensions and tried to re-assign. 6 of them connected and are working to a certain extent but 2 of them refuse to register.
    Also, the phones that were on DND for the weekend when connecting to the new system are stuck in DND mode (even though it doesn't show on the phone or the softphone connected). calls to those phones don't ring and go directly to voicemail.
    Tech support has been looking into logs and wireshark data all day and has no suggestions.
    Any thoughts?
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    What version firmware are the Yealinks running ? Are they remote or local ?
    I assume you checked that the 2 phones failing to register haven't been blacklisted ??
    Phones in DND : Take them off DND right in 3cx Extensions / forwarding rules.
    .... is it 3cx support that's been looking at the wireshark data ?! Somehow I doubt it ... This can't be that hard to figure out.
  3. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    you went from 12 or 12.5 ? (from memory you can't go from 12 direct to 15, 12.5 yes)
  4. Patrick Hogan10
    Nov 23, 2016
    27
    Having the same problem. Anyone here who knows how to fix this?
  5. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    ok then same question, did you upgrade from 12 to 15 like the original post says ?
  6. dean@insurewithstarr.com
    Aug 1, 2016
    upgraded to V15 from 12.5 Service Pack 2 Phones all upgraded to the latest firmware.
    3cx tech support last heard from 20 hrs ago: Being Processed since 20 hours 36 minutes I think my tech guy may have passed away in the night.
    I couldn't go through another day with things being flakey so reverted back to V12.5
    teldata1 likes this.
  7. complex1
    complex1 Active Member
    Jan 25, 2010
    829
    50
    After the upgrade from vxx to v15, did you run the firewall checker?
    Also the T48G phones must run on the by 3CX supported firmware, please don’t forget to reset the phones to default after you upgrade the phone firmware and Re-provision the phones again.
  8. GiannosC_3CX
    GiannosC_3CX Guest
    Hi dean@insurewithstarr.com,
    As far I can see you have open ticket on 3CX ticketing support, please continue the troubleshooting there.
