Upgrade V12.5 to V14 Licence question
Discussion in '3CX Phone System - General' started by Barnesm6, Sep 23, 2015.
  1. Barnesm6
    Jan 9, 2014
    10
    We purchased v12 earlier this year which includes one year maintenance so as I understand it we can upgrade to v14 at no cost. My question is do I need a new licence number or can I use the V12 licence to activate V14?
  2. positron
    Jan 14, 2013
    74
    9
    As long as your maintenance has not expired, the same license key is used to activate v14. Your current license key will be restored and activated when you restore your data from the v12.5 backup.
  3. Barnesm6
    Jan 9, 2014
    10
    Thanks for that.
  4. chris.moses
    Sep 13, 2015
    19
    Just verifying that this is indeed how my system behaved when I upgraded. The restore pulled in the correct license and maintenance end date.
  5. acatt
    Oct 20, 2015
    I updated to v14 and then restored the v12.5 backup, but it did NOT restore my license.
    When I manually try to install the license, I first got the error "This license key is already activated on this server." (V14 is on a new Hyper-V machine, Windows 2008).
    I went into the old VM and converted it to a free instance, but that did not solve the problem.
    I deleted the blue keys from regedit, and now when I enter the key, it correctly displays my version until I leave the license window, when it reverts to a free instance.
    Please help! Thanks!
  6. acatt
    Oct 20, 2015
    I forgot to mention: I'm getting an Server activity log error:
    License Info: Load Failed - 47
  7. CentrexJ
    CentrexJ Member
    May 5, 2009
    380
    50
    You need to put in a ticket with 3CX support to have them fix this. It is likely locked to the MAC address of the old server. Send them your license key to speed things up. If you are not a reseller go through the company you used to make the purchase and have them submit the ticket.
